[GRASS-dev] GRASS7: makefile issue with -j4
Martin Landa landa.martin at gmail.com
Fri Oct 14 13:27:38 EDT 2011
2011/9/30 Martin Landa <landa.martin at gmail.com>:
>> FWIW, this approach has been committed as r48561.
> thanks, no errors reported. Martin
unfortunately this approach has one strange side-effect, it deletes
images at the end.
cd gui/wxpython/docs
python /usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/tools/mkhtml.py
wxGUI.Vector_Digitizer 2011 >
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI.Vector_Digitizer.html
rm /usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI_nviz_tools_volume.jpg
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI_nviz_tools_view.jpg
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI_layer_manager.jpg
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI_nviz_tools_surface.jpg
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI_nviz_toolbar.jpg
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI_map_display.jpg
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI_nviz_tools_vector.jpg
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI_GCP_Manager.jpg
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI_modeler.jpg
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI_nviz_tools_light.jpg
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI_vector_digitizer_toolbar.jpg
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
