[GRASS-dev] Re: [GRASS GIS] #1463: Legend, Zoom to map,
Map analysis and Map query does not work in Python wxgui using
command line d.mon + d.rast
trac at osgeo.org
Sat Oct 15 07:13:49 EDT 2011
#1463: Legend, Zoom to map, Map analysis and Map query does not work in Python
wxgui using command line d.mon + d.rast
Reporter: huhabla | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: d.mon | Platform: Unspecified
Cpu: Unspecified |
Comment(by huhabla):
Is it possible to create an "invisible" dummy LayerTree, filled with
information about the map to be drawn from command line? So that the
depending functionality in mapdisplay.py works?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1463#comment:1>
