[GRASS-dev] Re: [GRASS GIS] #1459: X Window System error
trac at osgeo.org
Sat Oct 15 13:53:46 EDT 2011
Reporter: andressilvam | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone:
Component: wxGUI | Version: 6.4.1
Keywords: | Platform: Linux
Cpu: x86-64 |
Changes (by artegion):
* version: unspecified => 6.4.1
Comment:
I've found the same error with GRASS 6.4.1 (2011) and Ubuntu 11.10
from GIS Layer manager selecting "add vector(Ctrl+V)",selecting some cat
(d.vect map=somemap at PERMANENT type=point,line cats=1)
press OK
(then re-open this layer (double click on it) , press again OK )* (two or
three times)
The program 'python' received an X Window System error.
This probably reflects a bug in the program.
The error was 'RenderBadPicture (invalid Picture parameter)'.
(Details: serial 73623 error_code 174 request_code 152 minor_code 7)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error()
function.)
if I restart wxPython gui from terminal (g.gui) error message changes:
(.:3114): Pango-CRITICAL **: pango_layout_get_cursor_pos: assertion `index
>= 0 && index <= layout->length' failed
The program '.' received an X Window System error.
The error was 'BadDrawable (invalid Pixmap or Window parameter)'.
(Details: serial 176891 error_code 9 request_code 152 minor_code 4)
function.)
but sometimes error is:
GRASS 6.4.1 (wgs84_UTM32):~ > g.gui
[xcb] Unknown request in queue while dequeuing
[xcb] Most likely this is a multi-threaded client and XInitThreads has not
been called
[xcb] Aborting, sorry about that.
wxgui: ../../src/xcb_io.c:178: dequeue_pending_request: asserzione
"!xcb_xlib_unknown_req_in_deq" non riuscita.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1459#comment:2>
