[GRASS-dev] Re: [GRASS GIS] #1472: wxgui layer manager output pane
breaks PRIMARY X selection
trac at osgeo.org
Sun Oct 16 20:41:36 EDT 2011
#1472: wxgui layer manager output pane breaks PRIMARY X selection
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: wxGUI | Version: svn-trunk
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Comment(by cmbarton):
The only place that I can find this called is in the new stats display
option for analysis graphs and in menuform.py that formats the dialogs for
all GRASS command modules. The command...
wx.TheClipboard.UsePrimarySelection(True)
is commented out in line #735. Enabling this has no effect one way or the
other on my Mac. I don't know what it would do on other platforms. But in
this case, copying is done via button and not selected text anyway.
The issue you are having with the output console is a different one. There
is a method that turns copying on an off at line #642 in output.py (def
SetCopyingOfSelectedText(self, copy):)
I'm not sure why anyone would want copying off by default. But perhaps
there is a reason.
When copying is on, it calls the Copy method of wx.StyledTextCtrl. AFAICT,
there is no option with stc.Copy() to use the primary or normal clipboard.
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/1472#comment:7>
