[GRASS-dev] C function which returns raster and additional info?
Markus Neteler
neteler at osgeo.org
Wed Oct 19 02:36:58 EDT 2011
On Tue, Oct 18, 2011 at 10:26 AM, Rainer M Krug <r.m.krug at gmail.com> wrote:
> If this mail has made it already to the lst, I apologise - I just could not
> find it anywhere.
> Hi
> I am thinking about the possibility of loading raster directly from GRASS
> into R, to avoid the overhang of saving to disk and loading again or having
> gdal in between GRASS and R.
> As R (using the sp package) holds the raster in memory, I was thinking about
> reading the data from GRASS by using a C function, returning the cell values
> and additional info (at least the one provided in esri ACSII file, i.e.
> NCOLS, NROWS, XLLCORNER, YLLCORNER, CELLSIZE, NODATA_VALUE) plus
> geo-referencing info, so that, back in R, this data can be assembled to
> become a spatial object (SpatialGridDataFrame, as defined in the package
> sp).
An option may be to
- open the raster map,
- set computational region to the map
- read G_get_window()
http://grass.osgeo.org/programming6/get__window_8c.html#ada28852284056440f08c032e64a80765
Markus
