[GRASS-dev] [GRASS GIS] #1477: error running v.what.vect under
Windows/Osgeo4w
trac at osgeo.org
Thu Oct 20 15:05:55 EDT 2011
#1477: error running v.what.vect under Windows/Osgeo4w
Reporter: lutra | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Vector | Version: svn-trunk
Keywords: | Platform: MSWindows 7
Cpu: Unspecified |
I'm testing GRASS (6.4.2rc148715m) under Windows/Osgeo4w.
v.what.vect fails with
v.what.vect vector=dtm_points at PERMANENT =point layer=1 column=amostra4
qvector=fregue at PERMANENT =area layer=1 qcolumn=NOME_COM
Option does not accept multiple answers
Description:
Uploads vector values at positions of vector points to the table.
Keywords:
vector, database, attribute table
Usage:
v.what.vect vector=name [layer=value] column=string qvector=name
[qlayer=value] qcolumn=string [dmax=value] [--verbose] [--quiet]
Flags:
--v Verbose module output
--q Quiet module output
Parameters:
vector Vector map to modify
layer Layer in the vector to be modified
default: 1
column Column to be updated with the query result
qvector Vector map to be queried
qlayer Layer of the query vector containing data
default: 1
qcolumn Column to be queried
dmax Maximum query distance in map units
default: 0.0
Finished with error
under Linux the same operation, with the same vectors it works fine.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1477>
