[GRASS-dev] Re: [GRASS GIS] #1470: v.out.ascii with sql where option exports only centroids and not areas
GRASS GIS trac at osgeo.org
Fri Oct 21 04:17:07 EDT 2011
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.3
Component:  Vector       |     Version:  svn-trunk
 Keywords:  v.out.ascii  |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by mmetz):
 Replying to [comment:6 martinl]:
 > Replying to [comment:5 mmetz]:
 > > There is enough code in GRASS (other modules, libs) that takes care of
 such cases, boundaries would not be written twice. Basically a boundary
 would be written out if the centroid of any of its two areas has a cat
 value which is in the list. I would like to see that option/functionality
 in `v.out.ascii` because most of the time the vector objects a user works
 with are points, lines, areas. Modules/libs then take care of appropriate
 handling of boundaries and centroids.
 > right, please try out r48886 and r48887 (trunk).
 I have modified r48886 to avoid segfaults and r48887 to open vectors with
 topology only when needed (partially restoring original behaviour to
 support fast export of massive point vectors).
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1470#comment:7>
