[GRASS-dev] Avoiding maximum open files limit in r.series
Glynn Clements
glynn at gclements.plus.com
Fri Oct 21 11:46:45 EDT 2011
Sören Gebbert wrote:
> While implementing spatio-temporal data import and export using
> r.in.gdal, r.out.gdal and r.external i found some strange behavior:
> The export of raster data works fine, but the import/linking needs a
> lot more time than expected. Export with r.out.gdal 0.033s,
> link/import r.external or r.in.gdal ~17s:
I don't think that this is related to my changes.
Does passing the -c flag to r.out.gdal significantly affect the time
taken to import the resulting file?
