[GRASS-dev] How to compile a script in GRASS
Luisa Peña luisapena1979 at gmail.com
Mon Oct 24 10:06:27 EDT 2011
I have tried your suggestion
sudo make MODULE_TOPDIR=/usr/lib64/grass641/
No.. That folder does not exist
2011/10/24 Markus Neteler <neteler at osgeo.org>
> On Mon, Oct 24, 2011 at 1:11 PM, Luisa Peña <luisapena1979 at gmail.com>
> wrote:
> > Hi Markus
> (please keep it on the list)
> > I have tried
> ... what? need to know it.
> Does
> /usr/lib64/grass-6.4.1/include/Make/
> exist?
> Markus
> > and I got:
> > Makefile:5: /usr/lib64/grass-6.4.1/include/Make/Script.make: No such file
> or
> > directory
> > make: *** No rule to make target
> > `/usr/lib64/grass-6.4.1/include/Make/Script.make'.  Stop.
> > The thing is that there is no Include/Make in my GRASS folder. But I have
> > installed grass+libs+devel packages
> >> On Mon, Oct 24, 2011 at 10:27 AM, Luisa Peña <luisapena1979 at gmail.com>
> >> wrote:
> >> > Greetings
> >> > I have installed GRASS 6.4.1 from ELGIS.argeo repository
> (grass.x86_64)
> >> > and
> >> > installed. Also I have installed grass-devel package fromt he same
> >> > repository. What is not correc in this?
> >> Yes it is. The question where your module is stored. If it is outside
> >> the GRASS source code directory then you need to tell "make" where
> >> to find it.
> >> # adapt path to your system:
> >> Hope this helps
> >> Markus
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20111024/315eee1a/attachment.html
