[GRASS-dev] Re: [GRASS GIS] #498: r.sun2 commissioning trials
trac at osgeo.org
Mon Oct 24 11:55:46 EDT 2011
Reporter: hamish | Owner: hamish
Type: defect | Status: assigned
Priority: major | Milestone: 6.4.2
Component: Raster | Version: svn-develbranch6
Keywords: r.sun | Platform: All
Cpu: All |
Comment(by dylan):
Has any progress been made on this topic? I recently re-computed an annual
global radiance calculation with GRASS7 (previously with GRASS65), using
only the elevation input (previously used elev, slope, aspect). The
results were astounding. Zooming into a smaller region and checking, it
appears as if the reflected radiance raster was all 0s and the diffuse
radiance raster was a vertical gradient across the region-- with no
apparent influence from the local terrain. When using slope and aspect
inputs the output appears to be correct.
I'll work up examples tonight and re-post with figures, code, and the DEM
in question.
Ticket URL: <https://trac.osgeo.org/grass/ticket/498#comment:17>
