[GRASS-dev] Re: [GRASS GIS] #1477: error running v.what.vect under Windows/Osgeo4w
GRASS GIS trac at osgeo.org
Tue Oct 25 09:35:42 EDT 2011
  Reporter:  lutra        |       Owner:  grass-dev@…
      Type:  defect       |      Status:  closed
  Priority:  major        |   Milestone:  6.4.3
 Component:  Vector       |     Version:  svn-trunk
Resolution:  invalid      |    Keywords:
  Platform:  MSWindows 7  |         Cpu:  Unspecified
Comment(by lutra):
 > This is a QGIS (or better to say GRASS plugin) bug. You should report it
 in QGIS tracker.
 Probably is not true.
 I made a few further tests, using various QGIS standalone installers,
 that were all made using osgeo4w packages. Every installer was shipped
 with his own copy/version of GRASS. I obtain the GRASS version by
 issuing g.version from the GRASS shell.
 From QGIS 1.5 to 1.7 it all works fine. Things got broken with QGIS
 1.7.1 which ships GRASS 6.4.2
 The command I tested were
 v.what.vect vector=pontos at mapset_agueda =point layer=1 column=puppa
 qvector=freguesias at mapset_agueda =area layer=1 qcolumn=NOME_COM
 v.generalize input=provincias at mapset_agueda type=area layer=1 -c
 type=boundary method=douglas threshold=100 look_ahead=7 reduction=50
 slide=0.5 angle_thresh=3 degree_thresh=0 closeness_thresh=0
 betweeness_thresh=0 alpha=1.0 beta=1.0 iterations=1 layer=1 output=puppa
 They works ok with
 QGIS 1.5
 GRASS 6.4.0svn (2010)
 QGIS 1.6
 GRASS 6.4.0 (2010)
 QGIS 1.7
 GRASS 6.4.1 (2011)
 They don't work with
 QGIS 1.7.1
 GRASS 6.4.2RC148715M (2011)
 The QGIS/GRASS plugin hasn't changed between QGIS 1.7 and 1.7.1
Ticket URL: <http://trac.osgeo.org/grass/ticket/1477#comment:8>
