[GRASS-dev] r.mapcalc in Python script (parse error)
Margherita Di Leo dileomargherita at gmail.com
Tue Oct 25 15:58:31 EDT 2011
Hi all,
I need a little help with r.mapcalc syntax in Python script. I want to
convert the following formula:
grass.run_command('r.mapcalculator', amap = r_stream+'_nothin' , formula =
'%s*%s' % (r_stream+'_nothin', r_mask) , outfile = r_stream+'_nothin',
overwrite = True)
I want to use r.mapcalc instead of r.mapcalculator. So I write:
grass.mapcalc("$r_stream_nothin = $r_stream_nothin * $r_mask",
                      r_mask = r_mask,
                      r_stream_nothin = r_stream+'_nothin')
but I get parse error. What's the correct way to do this? The aim is to add
the suffix '_nothin' to the existing variable name r_stream.
Thank you in advance.
Regards,
madi
Eng. Margherita Di Leo
Ph.D. Candidate
Methods and Technologies for Environmental Monitoring
Department of Environmental Engineering and Physics (DIFA)
University of Basilicata
Campus Macchia Romana
85100 - Potenza
Italy
Office: +39-0971205360
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20111025/d6b3da00/attachment.html
