[GRASS-dev] Re: [GRASS GIS] #1479: error running v.generalize under
Windows/Osgeo4w
trac at osgeo.org
Wed Oct 26 16:23:41 EDT 2011
#1479: error running v.generalize under Windows/Osgeo4w
Reporter: lutra | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone:
Component: Vector | Version: svn-trunk
Resolution: invalid | Keywords:
Platform: MSWindows 7 | Cpu: Unspecified
Changes (by mmetz):
* status: new => closed
* resolution: => invalid
Comment:
The question is if GRASS should accommodate the QGIS/GRASS plugin or if
the QGIS/GRASS plugin should accommodate GRASS. From a GRASS perspective,
the answer is obviously that the QGIS/GRASS plugin should adhere to GRASS
standards. That means no duplicate options like layer=1 layer=1, no
options like =area. Therefore this bug is a QGIS/GRASS plugin bug and not
a GRASS bug. Closing as invalid.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1479#comment:1>
