[GRASS-dev] Re: [GRASS GIS] #1477: error running v.what.vect under Windows/Osgeo4w
GRASS GIS trac at osgeo.org
Thu Oct 27 15:31:07 EDT 2011
  Reporter:  lutra        |       Owner:  grass-dev@…
      Type:  defect       |      Status:  reopened
  Priority:  major        |   Milestone:  6.4.3
 Component:  Vector       |     Version:  svn-trunk
Resolution:               |    Keywords:
  Platform:  MSWindows 7  |         Cpu:  Unspecified
Comment(by mmetz):
 Replying to [comment:10 neteler]:
 > Since v.what.vect is simply a wrapper for v.distance, it would be
 essential to add shell
 > debugging (add -x in the first line) to v.what.vect to understand how
 v.distance
 > is called.
 I'm pretty sure the reason why all the above commands no longer work with
 6.4.2 is the bug fix for #1444. AFAICT, this fix is correct and causes the
 parser to be a bit more unforgivable for invalid options. As stated in
 comment:6, this is a QGIS/GRASS plugin problem. This plugin should produce
 valid commands because it can parse the interface description and use this
 information to construct a valid command, just like the GRASS GUIs do. Are
 there no maintainers for the QGIS/GRASS plugin?
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1477#comment:11>
