[GRASS-dev] Re: grass-dev Digest, Vol 68, Issue 41
Glynn Clements
glynn at gclements.plus.com
Thu Oct 27 23:43:23 EDT 2011
Michael Barton wrote:
> In the second statement, I think the format should be...
> grass.mapcalc("'%s_nothin' = '%s_nothin' * '%s'" % (r_stream, r,stream, r_mask))
> Using the "$" does not work on my system at least.
grass.mapcalc() substitutes the arguments into the expression using
string.Template.substitute():
http://docs.python.org/library/string.html#template-strings
