[GRASS-dev] [GRASS GIS] #1481: v.in.ogr with postgis layers fails
if the table
schema is on the first place in the search_path of the database
trac at osgeo.org
Fri Oct 28 03:27:04 EDT 2011
#1481: v.in.ogr with postgis layers fails if the table schema is on the first
Reporter: tomdb | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Vector | Version: 6.4.1
Keywords: | Platform: Linux
Cpu: Unspecified |
The command
v.in.ogr dsn="PG:dbname=XXX user=XXX host=XXX" layer=venue.stand_lines
output=lines type=boundary
fails if the schema "venue" is on the first place of the search path of
the database XXX. The same command without the schema definition (
"layer=stand_lines") works fine as expected.
Examples:
XXX=>ALTER DATABASE XXX set search_path = venue,public;
GRASS 6.4.1 (xy):~/grassdata/xy >v.in.ogr dsn="PG:dbname=XXX user=XXX
host=localhost " layer=venue.stand_lines output=lines type=boundary
--overwrite
WARNING: Vector map <lines> already exists and will be overwritten
ERROR: Layer <venue.stand_lines> not available
host=localhost " layer=stand_lines output=lines type=boundary --overwrite
...works fine....
XXX=>ALTER DATABASE XXX set search_path = public,venue;
GRASS 6.4.1 (xy):~/grassdata/xy > v.in.ogr dsn="PG:dbname=XXX user=XXX
--overwrite
...works fine....
...works fine....
XXX=>ALTER DATABASE XXX set search_path = public;
--overwrite
...works fine....
Ticket URL: <http://trac.osgeo.org/grass/ticket/1481>
