[GRASS-dev] [GRASS GIS] #1483: need error trapping in cartographic
composer
trac at osgeo.org
Sat Oct 29 01:51:47 EDT 2011
#1483: need error trapping in cartographic composer
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: ps.map, cartographic composer | Platform: Unspecified
Cpu: Unspecified |
If you do the following, you get an error in the GUI for ps.map
1. create a map frame and add a map to it
2. close the map frame dialog
3. reopen the map frame dialog and select delete under the menu (why can't
you delete a single map instead of deleting the whole frame??)
4. without closing the map frame dialog, select another map and add it
(note that the map frame is gone from the thumbnail).
5. click "apply"
Here is the error:
File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc
/gui/wxpython/gui_modules/psmap_dialogs.py", line 1966, in
OnApply
okR = self.rPanel.update()
/gui/wxpython/gui_modules/psmap_dialogs.py", line 2616, in
update
if self.rasterDict['raster'] != map['drawMap']:
TypeError
list indices must be integers, not str
I found this in the most recent build of GRASS 7 (28-October-2011) but
don't know if it affects other versions as well (probably does).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1483>
