[GRASS-dev] Re: [GRASS GIS] #1483: need error trapping in
cartographic composer
trac at osgeo.org
Sun Oct 30 11:58:50 EDT 2011
#1483: need error trapping in cartographic composer
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: ps.map, cartographic composer | Platform: Unspecified
Cpu: Unspecified |
Comment(by annakrat):
I assume that some of these errors probably result from opening more
modeless dialogs at the same time. The situation you described here seemed
very improbable to me. If you want to remove raster without removing the
frame, you can do it in the raster dialog by choosing the 'no raster map'
option.
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1483#comment:3>
