[GRASS-dev] Re: [GRASS GIS] #1483: need error trapping in cartographic composer
GRASS GIS trac at osgeo.org
Sun Oct 30 14:06:50 EDT 2011
 Reporter:  cmbarton                       |       Owner:  grass-dev@…
     Type:  defect                         |      Status:  new
 Priority:  normal                         |   Milestone:  7.0.0
Component:  wxGUI                          |     Version:  svn-trunk
 Keywords:  ps.map, cartographic composer  |    Platform:  Unspecified
      Cpu:  Unspecified                    |
Comment(by cmbarton):
 More information. The problem is with the dot-dashed line style. It looks
 really bad if you use it with streams in the nc07 demo data set and region
 set to match the elevation DEM. The dashed style doesn't look much better.
 A further problem is that if you put the same vector map in twice and try
 to have each layer of the vector styled differently (e.g., a wide line in
 one color, overlaid by a narrow line in a different color), both layers
 take on the properties of the most recent one defined. This may be
 happening with any vectors overlaid. I don't know if this is a wxGUI or
 ps.map problem.
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1483#comment:6>
