[GRASS-dev] Re: [GRASS GIS] #1380: WX-Python GUI,
menu does not work at all
trac at osgeo.org
Mon Oct 31 04:33:29 EDT 2011
#1380: WX-Python GUI, menu does not work at all
Reporter: naokiueda | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.2
Component: wxGUI | Version: 6.4.1 RCs
Keywords: encoding, wingrass | Platform: MSWindows 7
Cpu: Unspecified |
Comment(by Venkat):
Replying to [comment:14 hellik]:
> Replying to [comment:13 martinl]:
> > Replying to [comment:10 venkat]:
> > > Replying to [comment:8 martinl]:
> > > > Replying to [comment:4 venkat]:
> > > > > Tried with winGRASS on Windows-7 English and also Japanese
version
> > > > Do you problem also in English environment?
> > > Yes, the problem is also on Windows-7 English environment?
> > Anyone else with this problem? I wonder that something is bad with
your installation, see my previous notes.
> tested here
http://grass.osgeo.org/grass64/binary/mswindows/native/WinGRASS-6.4.2RC1-1-Setup.exe
on a fresh german 64bit-win7-box and on german 32bit-winvista-box, I can't
reproduce these errors.
Thanks for testing. The error cannot be reproduced on your computer
because "system locale" is perhaps set to german. System local can
be changed from Contro Panel --> Region and Language --> Change system
locale.
On Japanese Windows-7 the system locale is set to "Japanese".
(Japanese/Chinese/Korean are use double byte encoding, unlike English,
German etc.). d.rast wxGUI works if I set the "system locale" to English
or German (I tried with German too).
The problem that I am reporting is peculiar to languages using double-byte
characters (Chinese, Japanese, Korean). You should be able to reproduce
the error by setting the Change system locale to Japanese,
Venka
Ticket URL: <http://trac.osgeo.org/grass/ticket/1380#comment:15>
