[GRASS-dev] Re: [GRASS GIS] #1380: WX-Python GUI, menu does not work at all
GRASS GIS trac at osgeo.org
Mon Oct 31 10:14:04 EDT 2011
 Reporter:  naokiueda           |       Owner:  grass-dev@…
     Type:  defect              |      Status:  new
 Priority:  blocker             |   Milestone:  6.4.2
Component:  wxGUI               |     Version:  6.4.1 RCs
 Keywords:  encoding, wingrass  |    Platform:  MSWindows 7
      Cpu:  Unspecified         |
Comment(by hellik):
 Replying to [comment:15 Venkat]:
 > Thanks for testing. The error cannot be reproduced on your computer
 > because "system locale" is perhaps set to german. System local can
 > be changed from Contro Panel --> Region and Language --> Change system
 locale.
 > On Japanese Windows-7 the system locale is set to "Japanese".
 (Japanese/Chinese/Korean are use double byte encoding, unlike English,
 German etc.). d.rast wxGUI works if I set the "system locale" to English
 or German (I tried with German too).
 > The problem that I am reporting is peculiar to languages using double-
 byte characters (Chinese, Japanese, Korean). You should be able to
 reproduce the error by setting the Change system locale to Japanese,
 maybe change the title that an encoding issue is here the problem?
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1380#comment:16>
