[GRASS-dev] [GRASS GIS] #1434: g.extension: option to specify proxy
server
trac at osgeo.org
Sun Sep 4 20:12:00 EDT 2011
#1434: g.extension: option to specify proxy server
Reporter: hamish | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Installation | Version: svn-trunk
Keywords: g.extension, urllib, wget, r.in.wms | Platform: All
Cpu: All |
for folks who have to go through an auth'd proxy server to get a
connection to the internet g.extension reports a failure of
svn+urllib(.py) (or svn+wget,curl in 6.x) to download the files.
Something like 6.x's r.in.wms's wgetoptions= parameter could work around
this, or maybe urllib(.py) has some nicer way.
6.x work-around for wget/curl: export the http_proxy enviro variable
before starting GRASS. see the wget/curl man pages.
7.x work-around for urllib: same http_proxy enviro var as above, see also
http://docs.python.org/library/urllib.html
work-around for 'svn co', all versions: edit the "servers" file in
~/.subversion, or in MS Windows %APPDATA%\Subversion\.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1434>
