[GRASS-dev] [GRASS GIS] #1440: v.in.ogr's where clause cannot
handle uppercase column names for Postgres
trac at osgeo.org
Sun Sep 4 23:56:11 EDT 2011
#1440: v.in.ogr's where clause cannot handle uppercase column names for Postgres
Reporter: arencambre | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Vector | Version: unspecified
Keywords: | Platform: MSWindows 7
Cpu: x86-64 |
In Postgres, if a column name has upper case characters, it must be
surrounded by quote marks in SQL queries. If the column name is not
surrounded by quote marks, it is interpreted as lower case.
For example, if Postgres sees '''SELECT * FROM x WHERE AAaa = 'hi'''', it
looks for column '''aaaa''', which is not the same as '''AAaa'''. If you
want to match '''AAaa''', you have to use '''SELECT * FROM x WHERE "AAaa"
= 'hi''''.
There appears to be no variant of escaping that works correctly with this
with '''v.in.ogr''''s '''where''' parameter. For example, I have a column
named '''Cnty_ID'''. I've tried all these variants of the '''where'''
clause with no luck:
* '''"where="Cnty_ID" = '57'"''' -- translates to '''Cnty_Id = '57''''.
* '''"where=\"Cnty_ID\" = '57'"''' -- translates to '''\Cnty_ID\ =
'57''''.
* '''where=""Cnty_ID" = '57'"''' -- translates to '''Cnty_Id = '57''''.
* '''where="""Cnty_ID"" = '57'"''' -- translates to '''Cnty_Id = '57''''.
The only documentation I could find on escaping in commands is at
http://grass.osgeo.org/gdp/html_grass64/wxGUI.html.
This is happening on 6.4.1. (That option not available in the
'''Version''' dropdown.)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1440>
