[GRASS-dev] Re: [GRASS GIS] #548: grass7 - v.reclass with sqlite
driver: "Cannot step: SQL logic error or missing database"
trac at osgeo.org
Tue Sep 6 02:52:03 EDT 2011
#548: grass7 - v.reclass with sqlite driver: "Cannot step: SQL logic error or
missing database"
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Database | Version: svn-trunk
Keywords: v.reclass sqlite | Platform: Unspecified
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:10 mmetz]:
> Debugging a bit, the problem of v.reclass with the sqlite driver seems
to be that the same database is opened twice (once by each driver
instance), which causes database locking, therefore it is not possible to
use one driver instance to fetch records from one table and use another
driver instance to insert records into another table, all in the same
sqlite database.
Now it's possible, the other driver just has to wait a little bit until
the first driver is finished.
Fixed in r45156, r48157, r48158 (7.0, 6.5, 6.4.2, respectively).
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/548#comment:11>
