[GRASS-dev] Re: graphical modeler results
Michael Barton
Michael.Barton at asu.edu
Tue Sep 6 16:09:33 EDT 2011
A lot of things work much better on this. Thanks.
Here is a problem that I found with the newest version.
1) add a data object and pick a map or other element
2) select that data object and try to change the map/element
Raises the following error:
File "/Applications/GRASS/GRASS-6.4.app/Contents/MacOS/etc
/wxpython/gui_modules/gselect.py", line 218, in OnPopup
self.seltree.EnsureVisible(match)
/python/wx/_controls.py", line 5530, in EnsureVisible
return _controls_.TreeCtrl_EnsureVisible(*args, **kwargs)
wx._core
PyAssertionError
C++ assertion "item.IsOk()" failed at /BUILD/wxPython-
src-2.8.12.0/src/generic/treectlg.cpp(2107) in
EnsureVisible(): invalid tree item
I'm also getting an error if I set parameterization and run the model, but it may be related to this one.
A different issue is that you should be able to leave blank a field that you parameterize in the model. But this raises several error messages--although by ignoring them, you can go ahead and run the model and select the parameterized item.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Sep 6, 2011, at 11:54 AM, Martin Landa wrote:
> 2011/9/6 Michael Barton <Michael.Barton at asu.edu>:
>> Thanks for the enhancements. I'll test. Are these backported to all versions or just in 6.5 for now?
> everything is done in trunk and backported to devbr6 and relbr64 (it's
> marked as experimental prototype).
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
