[GRASS-dev] Re: [GRASS GIS] #1444: g.parser does not filter for
duplicate output map statements
trac at osgeo.org
Thu Sep 8 04:45:27 EDT 2011
#1444: g.parser does not filter for duplicate output map statements
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone: 6.4.2
Component: LibGIS | Version: 6.4.1
Keywords: parser | Platform: All
Cpu: All |
Comment(by glynn):
Replying to [comment:2 hamish]:
> It would seem that by design (at least in 6.5) if you use a command line
parameter more than once the parser concatenates them together with ',' as
the f.sep.:
Correct; this feature has existed since forever, but isn't widely known.
It can be useful in conjunction with e.g. xargs, as generating multiple
options is easier than trying to glue the values together into a single
option.
> if the particular option does not allow multiple="YES", you get an
error.
> perhaps a way to handle this is for the parser to be more upfront about
scanning for illegal map names &/or if multiple=NO?
Try r48205 (7.0).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1444#comment:3>
