[GRASS-dev] Re: [GRASS GIS] #1441: Hard Copy Map Utility (wxPython
wrapper for ps.map) text overlay is broken
trac at osgeo.org
Fri Sep 9 14:15:20 EDT 2011
#1441: Hard Copy Map Utility (wxPython wrapper for ps.map) text overlay is broken
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: wxGUI | Version: svn-trunk
Keywords: hard copy map utility, ps.map | Platform: Unspecified
Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:18 cmbarton]:
> I'm close to fixing this, but have not yet committed those changes
because they still have a few weird inconsistencies that have to do with
updating after a drag event. I'll see how your changes mesh with mine.
It's a pretty busy day today so I might not get to it until the weekend.
I appreciate your help however it would be more efficient if I try to fix
the problems first because I understand the code better (as the author).
On the other hand it's always better if someone else can understand and
maintain the code.
Maybe you could summarize the problems and inconsistencies you encountered
because I'm getting quite confused. Some problems may be platform
specific, some inconsistencies in wx.psmap have their origin in ps.map
module and I can explain them more.
Thanks Anna
Ticket URL: <https://trac.osgeo.org/grass/ticket/1441#comment:19>
