[GRASS-dev] GRASS 7 scripts overhaul
Markus Neteler neteler at osgeo.org
Mon Sep 12 16:23:21 EDT 2011
On Mon, Sep 12, 2011 at 8:24 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> > Try r48225.
>> Now a different one:
>> line 267, in main
>>     y, z = yz.split(' ')
>> ValueError: too many values to unpack
> I've improved m.proj as much as I can.
Thanks for your efforts!
Still...
v.out.gps -t input=railroads output=trail.gpx
  File "/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/scripts/m.proj",
line 288, in <module>
    main()
line 267, in main
    x, y = xy.split('\t')
ValueError: need more than 1 value to unpack
> The main problem is that, when cs2cs is run with the -E flag, it
> appears to copy the input semi-verbatim, meaning that the output
> format varies according to the input format. This makes it impossible
> to reliably parse the output from cs2cs.
I believe that cs2cs should get the equivalent to the -g flag in GRASS which
makes the output truely machine-readable.
Perhaps we concentrate on more important issues than v.out.gps and
let it rest for now. Thanks, Glynn, I am sure that m.proj is way better now.
Markus
