[GRASS-dev] Re: [GRASS GIS] #1400: preferences apply doesn't seem
to do anything
trac at osgeo.org
Tue Sep 13 12:18:11 EDT 2011
#1400: preferences apply doesn't seem to do anything
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: wxGUI | Version: unspecified
Keywords: preferences | Platform: MacOSX
Cpu: OSX/Intel |
Comment(by cmbarton):
Replying to [comment:3 martinl]:
> Replying to [comment:2 cmbarton]:
> > I went to test this and I cannot do so because the settings dialog is
modal in GRASS 6.4.2. So I can't tell if any setting changes are sticking
when I press the "apply" button. Because I cannot exit the settings dialog
to check until I press OK.
> are you speaking about GUI Settings dialog? There is no OK button, only
Cancel, Apply and Save. Dialog is not modal, and Apply closes the dialog.
I meant "save" instead of "OK".
This settings dialog is modal in GRASS 6.4.2 so I cannot test whether or
not the settings are applied or not without saving.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1400#comment:5>
