[GRASS-dev] Re: [GRASS GIS] #957: v.voronoi has extra lines in
output
trac at osgeo.org
Tue Sep 20 09:11:36 EDT 2011
#957: v.voronoi has extra lines in output
Reporter: helena | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.2
Component: Vector | Version: svn-develbranch6
Keywords: v.voronoi | Platform: All
Cpu: All |
Comment(by mmetz):
Replying to [comment:17 hamish]:
> Replying to [comment:16 mmetz]:
> > See comment:13 for a suggestion
> (thanks, I'd missed that)
> > > Therefore it may be a good idea to do the adjustment that
> > > g.region currently does in trunk/general/g.region/main.c#L549
> > > and following lines not only for window.north == window.south
> > > etc. but always, to make sure that all vector features are
> > > really inside the current region?
> By "always" you mean just when used with vect=, right? :)
Sure :- no absolute always implied here.
> The idea to round out by 1/2 a grid cell in each direction seems ok at
first, but I speculate about what the problems might be:
> - as res= is typically not set with vect=, what happens if original res
is quite large but vector bbox is very small? you get a big region as a
result when you wanted one orders of magnitude smaller.
Right, but that affects also the current behaviour of g.region
> - what if you have a series of vector points broken up by region (lidar
1km x 1km chunk files) and want to patch their bboxes together? would you
be better/worse/no worse than now?
The combination of g.region vect=myvect; v.in.region out=myvect_region can
exclude features in the current behaviour (%.8f precision). In this case
you could use the output of v.info -e plus v.in.ascii to get bboxes and
then patch them together (v.info could also get a new output option box
which writes the box to a vector).
> perhaps it is better to expand by some other proportional amount? like
the lesser of 1/2 a grid cell, or +/- (n-s)*1e-n ? (where n=6..15), or
+/- GRASS_EPSILON and change the WIND file (and thus all other
G_format_*()) to record to useless/impracticable/wasteful precision?
Does it harm to record .15g precision in the WIND file? Internally, it's
always stored as double AFAICT.The only harm I can see is
implying/suggesting a precision that is not justified by geospatial data.
(Unless someone does spatial analysis on electron microscope scans with
meters as unit, i.e. non-geo but spatial data).
> or hardcode the +/- 0.00000001 with a note that it should match the
precision in format_double()?
That one, hardcoding a fixed value matching the minimum precision in the
WIND file, makes most sense to me. GRASS_EPSILON has no effect with %.8f
since it's 1e-15.
> open to suggestions,
> Hamish
> ps- it is wonderful that this longstanding v.voronoi bug is near to
being fixed!
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:18>
