[GRASS-dev] Re: requring explicit input=-
Hamish
hamish_b at yahoo.com
Fri Sep 23 22:50:05 EDT 2011
Martin wrote:
> * `input=-` means that it will read data from standard input,
> so the command waits for that (it will wait for eternity if you
> do not provide any input;-)
I don't have a solution to that (probably common) problem, but
fwiw I suspect less often people will try "-" in the gui by mis-
understanding what stdin means, so the problem does not go away
completely.
shrug,
Hamish
