[GRASS-dev] v.generalize: flag -r removed?
Markus Metz markus.metz.giswork at googlemail.com
Mon Sep 26 04:35:10 EDT 2011
On Sat, Sep 24, 2011 at 6:38 PM, Hamish <hamish_b at yahoo.com> wrote:
> Paolo wrote:
>> > Apparently the flag -r has been recently removed. May I know
>> > the reason in a few lines? I have to adjust the QGIS the
>> > plugin, and I prefer to understand before doing.
> Markus M:
>> Until recently, v.generalize did not work with boundaries,
>> more generally, did not fully adhere to the grass vector
>> topology model.
>> The -r flag was one of the components causing damage, further
>> on it duplicated functionality covered be v.clean and made the
>> interface even more complex. Therefore it was removed while
>> overhauling the module.
> since this flag/feature was released in an official stable
> release it should not have been removed for future versions of
> the stable branch. If the feature was in fact too broken to be
> allowed to live, it should be replaced with a no-op -r flag with
> a description of
>    flag->description =
>        _("This does nothing. It is retained for backwards compatibility");
>    flag->guisection = _("Unused");
> any user script, addon module, documentation written since 6.0.0
> should continue to work with any version of grass 6 >= than the
> one it was written for, with at most needing a no-modification
> recompile. for years we have shown good discipline in this regard;
> doing so respects the users' confidence to invest their energy
> (once) and get on with their work, and makes grass a more
> dependable platform to base their infrastructure/work flow on.
> this is a blocker for 6.4.2.
The -r flag is restored in r48471,2 as suggested. IMHO, v.generalize
should not have been included in its original form in the
releasebranch in the first place.
Markus M
> thanks,
> Hamish
