[GRASS-dev] Re: [GRASS GIS] #1453: ps.map: various enhancements
trac at osgeo.org
Mon Sep 26 08:53:38 EDT 2011
Reporter: mmetz | Owner: hamish
Type: enhancement | Status: assigned
Priority: normal | Milestone: 7.0.0
Component: Ps.map | Version: svn-trunk
Keywords: | Platform: All
Cpu: All |
Comment(by hamish):
* #comments patch applied in trunk and devbr6
* 'point' width patch applied with modification in trunk
further discussion:
- I remember now why I split off the vpoints and put them over the grid
lines by default, for complicated symbols like extra/alpha_flag it didn't
look good to have them underneath when used to represent sampling
stations. currently you can control it with the 'masked y|n' command; I'm
open to changing the default 'y|n' there to go under the grid lines if
there is popular support for having it that way, but before abusing the
masked control I think we should better get the masked support working. I
don't fully understand what it's doing, but AFAICT by looking at
do_masking.c and r_plt.c, the help page is misleading/wrong, it doesn't
have much to do with raster MASK maps after all. AFAICT the maskcolor
instruction currently does nothing.
- FP color table border width: both new and old way is a bit weird. I'll
check in a compromise which gets rid of the overly wide wierdness, as a
base for further discussion. screenshots will be helpful here.
scalebar, vlegend: I haven't looked at these yet.
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1453#comment:5>
