[GRASS-dev] wxGUI: column name selector?
Martin Landa landa.martin at gmail.com
Tue Sep 27 17:26:59 EDT 2011
2011/9/27 Markus Neteler <neteler at osgeo.org>:
> while d.vect is able to provide in the wxGUI the list of available
> columns other modules are yet unable (v.db.univar, v.*).
it should work for almost all vector modules (please report modules,
where it doesn't work).
There is a bug in v.db.univar - option <table> wrongly defines
gisprompt for vector. Fixed in r48508.
BTW, I would expect from this module options like `map` and `layer`,
not `table`, `driver` and `database`. Modules `v.db.` should come with
`map` option, or I am wrong?
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
