[GRASS-dev] Re: [GRASS GIS] #287: vdigit: don't force 'cat' as the
key column name
trac at osgeo.org
Tue Sep 27 19:52:02 EDT 2011
#287: vdigit: don't force 'cat' as the key column name
Reporter: msieczka | Owner: martinl
Type: defect | Status: assigned
Priority: minor | Milestone: 6.4.3
Component: Default | Version: svn-develbranch6
Keywords: | Platform: All
Cpu: All |
Comment(by martinl):
Replying to [comment:5 martinl]:
> Replying to [comment:4 msieczka]:
> > Oh, it would be usefull for sure, but that's not exactly what I meant.
I meant that each command that creates a vector map with a linked table
should allow for specifying the key column name at it's runtime. Having
such functionality *and* a global variable for a default, would be
optimal.
> Try r48512 (trunk) or r48513 (devbr6).
Note that it affects only creating new vector maps dialog.
Ticket URL: <http://trac.osgeo.org/grass/ticket/287#comment:7>
