[GRASS-dev] Re: [GRASS GIS] #1184: "d.vect display=attr" imply grass open process but doesn't close them.
GRASS GIS trac at osgeo.org
Tue Sep 27 21:30:12 EDT 2011
 Reporter:  met               |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  critical          |   Milestone:  6.4.2
Component:  wxGUI             |     Version:  6.4.0
 Keywords:  wingrass, d.vect  |    Platform:  MSWindows XP
      Cpu:  Unspecified       |
Changes (by hamish):
  * keywords:  wingrass => wingrass, d.vect
Comment:
 Replying to [comment:5 hamish]:
 > what's more if you select disp=attr attrcol=label the wxGUI locks up
 with an endless
 > hourglass. the "this program is not responding" dialog helps you kill it
 and get
 > back to the working msys prompt where you can restart it with g.gui.
 (but the
 > `dbf.exe`s remain running)
 see also #1331
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1184#comment:6>
