[GRASS-dev] Re: [GRASS GIS] #1452: wx location wizard doesn't ask
for datum
transform options because proj4 4.7.1's epsg file is broken
trac at osgeo.org
Wed Sep 28 07:05:29 EDT 2011
#1452: wx location wizard doesn't ask for datum transform options because proj4
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Projections/Datums | Version: svn-releasebranch64
Keywords: wingrass, location wizard, wx | Platform: MSWindows XP
Cpu: x86-32 |
Comment(by hamish):
wingrass 6.5svn r48515 nightly build on XP w/MSys:
GRASS 6.5> g.gisenv set="DEBUG=3"
GRASS 6.5> g.proj proj4='+proj=longlat +datum=nad83' datumtrans=-1
D3/3: set_datumtrans(): datum transform terms found with 6 options
GRASS 6.5>
but no results printed!
also
#spearfish
g.region -d
g.region -n
WARNING: pj_transform() failed: failed to load datum shift file
ERROR: Error in pj_do_proj (projection of input coordinate pair)
`g.region -l` gives the same error.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1452#comment:6>
