[GRASS-dev] [GRASS GIS] #1633: Unable to display shapefile attribute table due to pipe characters in dbf field
GRASS GIS trac at osgeo.org
Tue Apr 3 04:20:39 EDT 2012
field
 Reporter:  richardc     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  critical     |   Milestone:  6.4.3
Component:  Display      |     Version:  6.4.1
 Keywords:               |    Platform:  Linux
      Cpu:  Unspecified  |
 I'm receiving the following error on attempting to view the attribute
 table of shapefiles in GRASS 6.4.1.2 (on Ubuntu Lucid):
 item = layer, log = self.goutput)
   File "/usr/lib/grass64/etc/wxpython/gui_modules/dbm.py",
 line 653, in __init__
 self.__createBrowsePage()
 line 698, in __createBrowsePage
 self.mapDBInfo, layer)
 line 95, in __init__
 keyColumn = self.LoadData(layer)
 line 247, in LoadData
 self.AddDataRow(i, record, columns, keyId)
 line 286, in AddDataRow
 if self.columns[columns[j]]['ctype'] != types.StringType:
 IndexError
 list index out of range
 '''Method:'''
 I import the shapefile as follows:
 Layer Manager > File > Import vector data > Common import formats > Select
 ESRI shapefile > Browse and select file > Import
 And then select the layer in 'Layer Manager', and click on the 'Show
 attribute table' icon. Then the error results
 'Please wait loading attribute data..' with the following in the command
 console -
 IndexError
 On closer inspection of the dbf file, some of the fields contain pipe
 (i.e., '|') characters. On removing these the attribute table can be
 displayed.
 QGIS is able to display all data in the attribute table, including 'pipe'
 characters.
 Example of problem fields in single column named 'VARNAME_1,C,150':
 VARNAME_1,C,150
 Bangkok|Krung Thep|Krung Thep Maha Nakhon|Phra Nakhon-Thonburi
 Buri Rum
 Chaxerngsao|Pad Rew|Paed Riu|Petrieu|Shajeun Dhrao
 Chainat
 Chantaburi|Muang Chan
 NOTE: issue posted originally at http://osgeo-org.1560.n6.nabble.com
 /Index-error-Unable-to-show-attribute-table-of-shapefile-
 tp4678952p4678952.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/1633>
