[GRASS-dev] v.dissolve not working with string column
Michael Barton Michael.Barton at asu.edu
Wed Apr 4 01:56:55 EDT 2012
I'm trying to do a dissolve but keep getting an error saying that it only works with integer or string columns. But the column I'm using for the dissolve IS string.
GRASS 7.0.svn (Spain_utm_wgs84z30):~ > db.describe table=muro_temp
table:muro_temp
description:
insert:?
delete:?
ncols:4
nrows:177
column:cat
description:
type:INTEGER
len:20
scale:0
precision:0
default:
nullok:yes
select:?
update:?
column:Subsector
description:
type:TEXT
len:1000
scale:0
precision:0
default:
nullok:yes
select:?
update:?
column:valley
description:
type:TEXT
len:1000
scale:0
precision:0
default:
nullok:yes
select:?
update:?
column:sector
description:
type:TEXT
len:1000
scale:0
precision:0
default:
nullok:yes
select:?
update:?
GRASS 7.0.svn (Spain_utm_wgs84z30):~ > v.dissolve input=muro_temp column=sector output=muro_sectors3
ERROR: Key column must be of type integer or string
Note above that the column "sector" IS text.
So what is wrong?
_____________________
C. Michael Barton
Visiting Scientist, Integrated Science Program
National Center for Atmospheric Research &
University Consortium for Atmospheric Research
303-497-2889 (voice)
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu<http://csdc.asu.edu/>
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20120403/86e84643/attachment.html
