[GRASS-dev] removing small multiple polygons created by
r.stream.basin + r.to.vect
Margherita Di Leo
dileomargherita at gmail.com
Mon Apr 9 10:25:06 EDT 2012
Ciao Markus,
On Mon, Apr 9, 2012 at 3:47 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Wouldn't it be better to remove them with v.clean and rmarea to avoid
> holes?
just tried with:
grass.run_command('v.clean', input = v_basins,
output = v_basin,
type = 'area',
tool = 'rmarea',
thresh = 1, # I also tried 10
overwrite = True)
Maybe I do something wrong, but this way I can't get rid of small polygons,
and, in addiction, I need to set the threshold parameter, which I'm not
sure to be suitable for all cases...
where am I wrong?
Thanks,
madi
> Markus
Ing. Margherita Di Leo, Ph.D.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20120409/c14155dd/attachment.html
