[GRASS-dev] removing small multiple polygons created by
r.stream.basin + r.to.vect
Margherita Di Leo
dileomargherita at gmail.com
Mon Apr 9 13:35:11 EDT 2012
On Mon, Apr 9, 2012 at 6:43 PM, Margherita Di Leo <dileomargherita at gmail.com
> wrote:
> On Mon, Apr 9, 2012 at 5:54 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Mon, Apr 9, 2012 at 4:25 PM, Margherita Di Leo
>> <dileomargherita at gmail.com> wrote:
>> > Ciao Markus,
>> > On Mon, Apr 9, 2012 at 3:47 PM, Markus Neteler <neteler at osgeo.org>
>> wrote:
>> >> Wouldn't it be better to remove them with v.clean and rmarea to avoid
>> >> holes?
>> > just tried with:
>> > grass.run_command('v.clean', input = v_basins,
>> > output = v_basin,
>> > type = 'area',
>> > tool = 'rmarea',
>> > thresh = 1, # I also tried 10
>> > overwrite = True)
>> > Maybe I do something wrong, but this way I can't get rid of small
>> polygons,
>> what is exactly happening? Nothing or some are removed?
> In this case, nothing is removed. I'll give it some more try..
Looks like small areas are removed, but the table associated to the vector
map is not updated, hence the records of the small areas are still present
(cat = 2 and cat = 3). My error? What am I missing?
Ing. Margherita Di Leo, Ph.D.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20120409/1d857198/attachment.html
