[GRASS-dev] Re: [GRASS GIS] #1641: overwrite flag not mentioned in help file r.mask
GRASS GIS trac at osgeo.org
Mon Apr 16 16:59:33 EDT 2012
 Reporter:  pvanbosgeo         |       Owner:  grass-dev@…
     Type:  defect             |      Status:  new
 Priority:  normal             |   Milestone:  7.0.0
Component:  Default            |     Version:  unspecified
 Keywords:  help file, r.mask  |    Platform:  All
      Cpu:  x86-64             |
Comment(by glynn):
 Replying to [comment:1 neteler]:
 > Indeed, r.mask --help lacks
  --o   Allow output files to overwrite existing files
 > I don't know why - to be fixed.
 Because r.mask doesn't have any options with "gisprompt: new,..." (the
 output map name is hard-coded as "MASK", so there isn't any suitable
 option).
 In C modules, you can force --o to be documented by setting the
 "overwrite" field of the GModule structure before calling G_parser(), but
 there isn't any way to do this for scripts (it would require an
 enhancement to g.parser).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1641#comment:2>
