[GRASS-dev] disabling compression
Maris Nartiss
maris.gis at gmail.com
Wed Apr 25 03:24:21 EDT 2012
There's already an existing GRASS_INT_ZLIB env variable. There should
be only one env variable to enable/disable raster compression.
Just my 0.002 Verizon cents.
Maris.
2012. gada 24. aprīlis 18:02 Jim Regetz <regetz at nceas.ucsb.edu> rakstīja:
> Chagrined by a performance hit apparently involving zlib compression, I
> patched my local GRASS 7.0 to accept an environment variable that disables
> raster compression. At least for the particular DCELL rasters I've been
> using, this yields a ~5x improvement in run time during write operations, at
> a cost of some extra disk usage that I'm often more than happy to incur. See
> sample timing outputs below my sig.
> Admittedly, the speedup factor drops to ~2.5x if the timing comparisons
> include a forced sync to disk, because uncompressed output means more IO.
> But that's still a nice speedup, and the disk IO cost may be of little
> consequence in cases where the raster can fit comfortably in the OS page
> cache and is an intermediate output that gets read back in during a
> subsequent step of a particular processing workflow (and perhaps then
> removed before ever being flushed to disk).
> My demo-purposes patch is attached. It just adds a GRASS_NO_COMPRESSION
> environment variable and then injects a new conditional dispatch into each
> of the three Rast_open{_,_fp_,_c_}new functions. For cleaner semantics, it
> might be better to keep the original functions but rename them as
> *_compressed (paralleling the existing *_uncompressed versions) for callers
> who really want/need to force compression (e.g., r.compress, which my patch
> in some sense "breaks" when the environment variable is set), but I didn't
> do this here. And I haven't looked hard to see if other modules/etc truly
> depend on the existing compression behavior.
> Any chance something like this could make it into trunk?
> As a real world example, I recently wrote a Python module that relies on
> r.mapcalc, r.neighbors, and r.samp.stats. With GRASS_NO_COMPRESSION set,
> total runtime dropped from 20 minutes to 10 minutes on a 12K by 12K input
> raster, with a disk usage differential that peaked at ~4GB during
> processing. Outputs were identical other than compression.
> Cheers,
> Jim
> James Regetz, Ph.D.
> Scientific Programmer/Analyst
> National Center for Ecological Analysis & Synthesis
> 735 State St, Suite 300
> Santa Barbara, CA 93101
> # timings performed on Ubuntu 10.04 with ample RAM and a recent
> # build of GRASS 7.0-svn with the applied patch
> # describe the 'test' raster used below; based on some 90m SRTM
> # data coerced to double precision
> GRASS 7.0.svn (tmp):~ > r.info -g test
> rows=4801
> cols=4801
> cells=23049601
> datatype=DCELL
> GRASS 7.0.svn (tmp):~ > r.univar test
> total null and non-null cells: 23049601
> total null cells: 0
> Of the non-null cells:
> n: 23049601
> minimum: 500
> maximum: 3139
> range: 2639
> mean: 1445.04
> mean of absolute values: 1445.04
> standard deviation: 336.437
> # using (default) zlib compression on write
> GRASS 7.0.svn (tmp):~ > g.gisenv set="OVERWRITE=1"
> GRASS 7.0.svn (tmp):~ > g.region rast=test
> GRASS 7.0.svn (tmp):~ > unset GRASS_NO_COMPRESSION
> GRASS 7.0.svn (tmp):~ > sync; echo 3 > /proc/sys/vm/drop_caches
> GRASS 7.0.svn (tmp):~ > time r.mapcalc "foo = test" --quiet
> real 0m13.209s
> user 0m12.660s
> sys 0m0.400s
> # after disabling compression on write
> GRASS 7.0.svn (tmp):~ > export GRASS_NO_COMPRESSION=1
> real 0m2.514s
> user 0m2.320s
> sys 0m0.170s
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
