[GRASS-dev] [GRASS GIS] #1650: v.net.salesman - add sequence output
GRASS GIS trac at osgeo.org
Mon Apr 30 15:37:31 EDT 2012
 Reporter:  gfleming     |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  6.4.3
Component:  Default      |     Version:  unspecified
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 it would be nice to have tsp sequence output available as a formal command
 option.
 in 6.4.1 if DEBUG is set to 2 then the node sequence is output after the
 arc sequence in the Cycle section.
 in 6.4.2 the node sequence is apparently output just by using --verbose.
 I'm sure it is a common use case not only to see the route as a map but to
 get the node-visiting-sequence as well (which is not always clear from the
 map).
 It is usable as is (comma delimited array), but it might also be useful to
 stdout or a db table. What could be most useful is another column attached
 to the nodes layer in the output called, say, 'sequence', containing the
 explicit order (1,2,3...)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1650>
