Michael Barton wrote: > I have not explicitly built with --with-nls. Is this required for > GRASS to use different language settings (i.e., po.* files)? For C modules and libraries, yes. Python code will probably ignore the --with-nls setting. -- Glynn Clements <glynn at gclements.plus.com>
