[GRASS-dev] Info about MS windows add-ons packaging
Margherita Di Leo
dileomargherita at gmail.com
Thu Aug 2 02:03:21 PDT 2012
Hi again,
some more info: she is running GRASS 6.4.2 and windows XP.
What is not obvious to me, but maybe re-thinking about it, actually can
make sense, is that add-ons for windows are not retrieved from the latest
add-on version but from the version corresponding to the age of grass core,
right? Sorry if this question could sound a silly one, but it's pretty far
from the logic used in Linux.. So maybe she would solve the problem
installing the night builds.. ?
Thanks
On Thu, Aug 2, 2012 at 10:40 AM, Margherita Di Leo <
dileomargherita at gmail.com> wrote:
> Hi all,
> I am trying to fix some issues related to my add-on "r.hazard.flood",
> since Carolina is trying to use it on MSwindows without success. She
> pointed me out this error message:
> On Thu, Aug 2, 2012 at 10:16 AM, Carolina Rogelis <c.rogeliz at gmail.com>wrote:
>> r.hazard.flood --overwrite --verbose map=ras_wshdtunj_5m at PERMANENTflood=flood mti=MTI
>> Traceback (most recent call last):
>> File "C:\Documents and Settings\rogel1\Application
>> Data\GRASS6\addons\r.hazard.flood.py", line 121, in <module>
>> sys.exit(main())
>> Data\GRASS6\addons\r.hazard.flood.py", line 100, in main
>> grass.run_command('r.clump', input = 'r_flood', output =
>> 'r_clump', flags = '-o')
>> File "C:\Program Files\GRASS
>> 6.4.2\etc\python\grass\script\core.py", line 189, in
>> run_command
>> ps = start_command(*args, **kwargs)
>> 6.4.2\etc\python\grass\script\core.py", line 167, in
>> start_command
>> args = make_command(prog, flags, overwrite, quiet,
>> verbose, **options)
>> 6.4.2\etc\python\grass\script\core.py", line 124, in
>> make_command
>> raise ScriptError("'-' is not a valid flag")
>> grass.script.core.ScriptError: "'-' is not a valid flag"
>> (Thu Aug 02 03:09:38 2012) Command finished (161 sec)
>> this is an old bug already fixed some months ago.. problem is that, to my
> knowledge, addOns on windows are pre-compiled and packaged in order to be
> downloaded and ready-to-use. In other words, the bug is already fixed, but
> the package she is using is still bugged. Am I wrong? Would it be possible
> to package the latest version for windows users?
> Thanks!
> Dr. Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20120802/102feca3/attachment.html>
