[GRASS-dev] locale problem solved - but have suggestion
Maris Nartiss
maris.gis at gmail.com
Tue Aug 7 08:25:56 PDT 2012
Sorry!
At one point I was thinking about adding necessary code, still I
forgot about it. Fixed in r52582.
Maris.
2012/8/7 Markus Neteler <neteler at osgeo.org>:
> On Sat, Aug 4, 2012 at 7:18 AM, Maris Nartiss <maris.gis at gmail.com> wrote:
>> Patch has been commited to trunk to get wider testing.
>> Fail reports welcome,
> Here we go :)
> After make distclean, when compiling without NLS support, I cannot start
> the GUI any more:
> GRASS 7.0.svn (patUTM32):/raw_data/lidar_raw/las13_format/toposys_optech2007
>> Traceback (most recent call last):
> File "/usr/local/grass-7.0.svn/etc/gui/wxpython/mapdisp/main.py",
> line 34, in <module>
> from core.render import Map
> File "/usr/local/grass-7.0.svn/etc/gui/wxpython/core/render.py",
> line 38, in <module>
> from core.settings import UserSettings
> File "/usr/local/grass-7.0.svn/etc/gui/wxpython/core/settings.py",
> line 1123, in <module>
> UserSettings = Settings()
> line 42, in __init__
> self._defaultSettings() # -> self.defaultSettings
> line 74, in _defaultSettings
> id_loc = self._generateLocale()
> line 59, in _generateLocale
> self.locs = os.listdir(os.path.join(os.environ['GISBASE'], 'locale'))
> OSError: [Errno 2] No such file or directory: '/usr/local/grass-7.0.svn/locale'
> Markus
