[GRASS-dev] [GRASS GIS] #1694: r.in.lidar tries to allocate way too much memory
GRASS GIS trac at osgeo.org
Tue Aug 7 16:53:23 PDT 2012
 Reporter:  torsti      |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  7.0.0
Component:  Raster      |     Version:  svn-trunk
 Keywords:  r.in.lidar  |    Platform:  Linux
      Cpu:  x86-64      |
Comment(by hamish):
 > See the r.in.xyz man page for discussion about it.
 the choice raster resolution in r.in.xyz and r.in.lidar has a profound
 effect on the result, and must be chosen wisely. I typically do several
 iterations at different raster resolutions and do some stats on the
 (masked) results to find the optimal one. I have purposely avoided having
 the modules make any attempt to choose that for you since it is such a
 dataset and purpose driven choice, and needs the human operator to
 consider factors beyond the numbers themselves.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1694#comment:4>
