[GRASS-dev] [GRASS-SVN] r52607 - grass/trunk/raster/r.lake
Martin Landa landa.martin at gmail.com
Fri Aug 10 02:44:42 PDT 2012
2012/8/10 Markus Neteler <neteler at osgeo.org>:
>> If this is a real problem, why fix the symptoms and not the cause?
>> That would probably be the macro defining _().
> +1
> It worked for the past 10-xx years, so I don't see a reason why
> messing up the code when one specific gcc version complains.
agreed, in any case such changes should be discussed in ML before
applying them in SVN.
grep "G_fatal_error(\"%s\", _(" * -R --include=*.c -l
general/g.proj/input.c
raster/r.lake/main.c
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
