[GRASS-dev] [GRASS GIS] #1696: Error message v.db.dropcol (Add-On Path)
GRASS GIS trac at osgeo.org
Tue Aug 14 02:55:40 PDT 2012
 Reporter:  jradinger      |       Owner:  grass-dev@…
     Type:  defect         |      Status:  new
 Priority:  normal         |   Milestone:  6.4.3
Component:  Shell Scripts  |     Version:  unspecified
 Keywords:                 |    Platform:  Unspecified
      Cpu:  All            |
 when I try to drop a column from a table I get following error message
 although the table is modified correctly:
 (Tue Aug 14 12:47:30 2012)
 v.db.dropcol map=sender_point at FIDIMO_Cele column=testcol
 /usr/local/grass-6.5.svn/scripts/v.db.dropcol: 1: eval: adin
 ger/05_GRASS/GRASS_Scripts=/home/radinger/U_Radinger/05_GRAS
 S/FIDIMO/FIDIMO_Script/fidimo for grass 6.x/r.fidimo: not
 found
 /usr/local/grass-6.5.svn/scripts/v.db.dropcol: 1: eval: /r.r
 dfilter=/home/radinger/U_Radinger/05_GRASS/FIDIMO/FIDIMO_Scr
 ipt/fidimo for grass 6.x/r.fidimo: not found
 (Tue Aug 14 12:47:31 2012) Command finished (1 sec)
 and here an extended output with the -x flag:
 (Tue Aug 14 13:00:50 2012)
 + [ -z /usr/local/grass-6.5.svn ]
 + [ map=sender_point at FIDIMO_Cele != @ARGS_PARSED@ ]
 + basename /usr/local/grass-6.5.svn/scripts/v.db.dropcol
 + CMDLINE=v.db.dropcol
 + CMDLINE=v.db.dropcol "map=sender_point at FIDIMO_Cele"
 "column=testcol"
 + export CMDLINE
 + exec g.parser
 + [ @ARGS_PARSED@ != @ARGS_PARSED@ ]
 + PROG=v.db.dropcol
 + g.tempfile pid=10834
 + TEMPFILE=/home/radinger/Documents/GRASS_locations/Cele_loc
 ation/FIDIMO_Cele/.tmp/grassgis/10834.0
 + [ 0 -ne 0 ]
 + [ -z /home/radinger/Documents/GRASS_locations/Cele_locatio
 n/FIDIMO_Cele/.tmp/grassgis/10834.0 ]
 + trap exitprocedure 2 3 15
 + g.gisenv
 + eval GISDBASE='/home/radinger/Documents/GRASS_locations';
 LOCATION_NAME='Cele_location'; MAPSET='FIDIMO_Cele'; ADDON_P
 ATH='/home/radinger/.grass6/addons:/home/radinger/.grass6/ad
 dons:/home/radinger/.grass6/addons:/home/radinger/.grass6/ad
 dons:/home/radinger/U_Radinger/05_GRASS/GRASS_Scripts:/home/
 radinger/U_R'; adinger/05_GRASS/GRASS_Scripts='/home/radinge
 r/U_Radinger/05_GRASS/FIDIMO/FIDIMO_Script/fidimo for grass
 6.x/r.fidimo'; /r.rdfilter='/home/radinger/U_Radinger/05_GRA
 SS/FIDIMO/FIDIMO_Script/fidimo for grass 6.x/r.fidimo';
 GRASS_GUI='wxpython';
 + GISDBASE=/home/radinger/Documents/GRASS_locations
 + LOCATION_NAME=Cele_location
 + MAPSET=FIDIMO_Cele
 + ADDON_PATH=/home/radinger/.grass6/addons:/home/radinger/.g
 rass6/addons:/home/radinger/.grass6/addons:/home/radinger/.g
 rass6/addons:/home/radinger/U_Radinger/05_GRASS/GRASS_Script
 + adinger/05_GRASS/GRASS_Scripts=/home/radinger/U_Radinger/0
 5_GRASS/FIDIMO/FIDIMO_Script/fidimo for grass 6.x/r.fidimo
 found
 + /r.rdfilter=/home/radinger/U_Radinger/05_GRASS/FIDIMO/FIDI
 + GRASS_GUI=wxpython
 + : /usr/local/grass-6.5.svn
 /home/radinger/Documents/GRASS_locations Cele_location
 FIDIMO_Cele
 + g.findfile element=vector file=sender_point at FIDIMO_Cele
 mapset=FIDIMO_Cele
 + eval name='sender_point at FIDIMO_Cele' mapset='FIDIMO_Cele'
 fullname='sender_point at FIDIMO_Cele' file='/home/radinger/Doc
 uments/GRASS_locations/Cele_location/FIDIMO_Cele/vector/send
 er_point'
 + name=sender_point at FIDIMO_Cele mapset=FIDIMO_Cele
 fullname=sender_point at FIDIMO_Cele file=/home/radinger/Docume
 nts/GRASS_locations/Cele_location/FIDIMO_Cele/vector/sender_
 point
 + [ ! /home/radinger/Documents/GRASS_locations/Cele_location
 /FIDIMO_Cele/vector/sender_point ]
 + v.db.connect map=sender_point at FIDIMO_Cele -gl layer=1 fs=|
 + cut -f2 -d|
 + table=sender_point
 + [ -z sender_point ]
 + cut -f3 -d|
 + v.db.connect -gl fs=| map=sender_point at FIDIMO_Cele layer=1
 + keycol=cat
 + cut -f4 -d|
 + database=/home/radinger/Documents/GRASS_locations/Cele_loc
 ation/FIDIMO_Cele/sqlite.db
 + cut -f5 -d|
 + driver=sqlite
 + col=testcol
 + [ testcol = cat ]
 + cut -d| -f1,2
 + v.info --q -c map=sender_point at FIDIMO_Cele layer=1
 + grep |testcol$
 + [ 0 -ne 0 ]
 + [ sqlite = sqlite ]
 + grep -v |testcol$
 + cut -d| -f1,2
 + cut -d| -f1
 + cat /home/radinger/Documents/GRASS_locations/Cele_location
 /FIDIMO_Cele/.tmp/grassgis/10834.0.coldesc
 + cut -d| -f2
 + paste -d  /home/radinger/Documents/GRASS_locations/Cele_lo
 cation/FIDIMO_Cele/.tmp/grassgis/10834.0.colnames /home/radi
 nger/Documents/GRASS_locations/Cele_location/FIDIMO_Cele/.tm
 p/grassgis/10834.0.coltypes
 + tr \n ,
 + sed s+,$++g
 + COLDEF=cat INTEGER,River TEXT,Station
 TEXT,Station_fullname TEXT,X_LambII INTEGER,Y_LambII
 INTEGER,X_Lamb93 INTEGER,Y_Lamb93 INTEGER,adj_X DOUBLE
 PRECISION,adj_Y DOUBLE PRECISION,N INTEGER
 + sed s+,$++g
 + tr \n ,
 + COLNAMES=cat,River,Station,Station_fullname,X_LambII,Y_Lam
 bII,X_Lamb93,Y_Lamb93,adj_X,adj_Y,N
 + echo BEGIN TRANSACTION;
 CREATE TEMPORARY TABLE sender_point_backup(cat INTEGER,River
 TEXT,Station TEXT,Station_fullname TEXT,X_LambII
 INTEGER,Y_LambII INTEGER,X_Lamb93 INTEGER,Y_Lamb93
 INTEGER,adj_X DOUBLE PRECISION,adj_Y DOUBLE PRECISION,N
 INTEGER);
 INSERT INTO sender_point_backup SELECT cat,River,Station,Sta
 tion_fullname,X_LambII,Y_LambII,X_Lamb93,Y_Lamb93,adj_X,adj_
 Y,N FROM sender_point;
 DROP TABLE sender_point;
 CREATE TABLE sender_point(cat INTEGER,River TEXT,Station
 PRECISION,adj_Y DOUBLE PRECISION,N INTEGER);
 INSERT INTO sender_point SELECT cat,River,Station,Station_fu
 llname,X_LambII,Y_LambII,X_Lamb93,Y_Lamb93,adj_X,adj_Y,N
 FROM sender_point_backup;
 CREATE UNIQUE INDEX sender_point_cat ON sender_point ( cat
 DROP TABLE sender_point_backup;
 COMMIT;
 + db.execute input=/home/radinger/Documents/GRASS_locations/
 Cele_location/FIDIMO_Cele/.tmp/grassgis/10834.0
 + [ 0 -eq 1 ]
 + cleanup
 + rm -f /home/radinger/Documents/GRASS_locations/Cele_locati
 on/FIDIMO_Cele/.tmp/grassgis/10834.0 /home/radinger/Document
 s/GRASS_locations/Cele_location/FIDIMO_Cele/.tmp/grassgis/10
 834.0.coltypes /home/radinger/Documents/GRASS_locations/Cele
 _location/FIDIMO_Cele/.tmp/grassgis/10834.0.colnames /home/r
 adinger/Documents/GRASS_locations/Cele_location/FIDIMO_Cele/
 + v.support map=sender_point at FIDIMO_Cele
 cmdhist=v.db.dropcol "map=sender_point at FIDIMO_Cele"
 "column=testcol"
 + exit 0
 (Tue Aug 14 13:00:52 2012) Command finished (1 sec)
 This might be related to ticket #1683 and is caused by a whitespace in one
 of the specified Add-On paths. This has been tested on Ubuntu 12.04 with
 GRASS 6.5SVN r52671.
 /johannes
Ticket URL: <http://trac.osgeo.org/grass/ticket/1696>
